Upgrading your rear axle nut.
Posted: Sun Sep 17, 2017 5:31 am
by Suzsmokeyallan
A post with photo I created over at the KC site.
http://www.kettleclinic.co.uk/kcforum/v ... 14&t=10240" onclick="window.open(this.href);return false;
Re: Upgrading your rear axle nut.
Posted: Sun Sep 17, 2017 7:23 am
by Mgmark
Nice! I like this kind of mod that cleans up the bike and simplifies service work.
Do you have a supplier in the US?
Mark
Posted: Sun Sep 17, 2017 7:38 am
by Suzsmokeyallan
Easy enough, order the rear axle nut and the tool kit box wrench (27mm) for the 1993 Honda CBR900RR. Both items should cost you under $20.00
Posted: Tue Dec 26, 2017 7:08 pm
by Suzsmokeyallan
To answer a question Evans Ward posed, cut the rear axle through the split pin holes then grind the end flush so the hole remnants just disappear. Also grind a slight taper around the edge so the threads are not sharp.
Posted: Tue Dec 26, 2017 7:43 pm
by Evans Ward
:) :up:
Posted: Wed Dec 27, 2017 9:47 am
by sportston
Cool mod. Do you know if the thread is the same on the gt380?
Posted: Wed Dec 27, 2017 8:31 pm
by Suzsmokeyallan
I believe the 380 axle is a smaller diameter.
Posted: Fri Dec 29, 2017 11:49 am
by sportston
Suzsmokeyallan wrote:I believe the 380 axle is a smaller diameter.
Ah I see. I shall have to do some homework to find out what smaller modern bike shares the same thread as the GT380.
Posted: Mon Jan 01, 2018 9:48 pm
by Suzsmokeyallan
Possibly one from an Early CBR600, you need to look around for the fujilock flange nut that will fit. Have a look at Kawasaki as well.
Posted: Tue Jan 02, 2018 5:48 am
The GT550 & GT380 both use real axle nut with part # 09141-16001.
Posted: Sat Jan 27, 2018 9:03 pm
by Mgmark
Suzsmokeyallan wrote:Easy enough, order the rear axle nut and the tool kit box wrench (27mm) for the 1993 Honda CBR900RR. Both items should cost you under $20.00
Here is the Honda part number for the nut.
90305-MB4-003
This mod does make it easier to pull the rear wheel assy. Nice!
Thanks Allan
