75 Suzuki GT550 M - Small Plastic Carb Drain Lines
Syd
Country: New Zealand
Suzuki 2-Strokes: 72 T500J, 72 Kaw H1-B, 71 CB750 K1, 67 A7SS
Post by Syd »
I am just about to fit the 5 clear plastic drain lines to the carb bowls and the two other points above the bowls. To help me, would anyone have a photo showing where these 5 lines should go to after the carbs? I assume they would all run in a bunch together to the back of the engine so that they can drain by gravity to the ground if required. There is a clip on the top center of engine casing after the carbs which I also assume would hold all these lines? Any help with this would be much appreciated, thanks.
Syd
Re: 75 Suzuki GT550 M - Small Plastic Carb Drain Lines
Post by Syd »
All sorted now...
