GT550 SRIS Oil Lines Correct Connection Squence
- Country: New Zealand
- Suzuki 2-Strokes: 72 T500J, 72 Kaw H1-B, 71 CB750 K1, 67 A7SS
Hello, I am just about to connect the 3 x small oil lines from the bottom of the crank case to each the 3 x cylinders and I just want to double check if the attached diagram from the GT550 service manual is based on looking at the front of the bike ie; the RH side would be correct when looking at the front of the bike as shown on the drawing Fig 7-4-1? I assume it is important to ensure the 3 x oil lines are connected in the correct sequence. Can anyone confirm that is correct before I proceed further? Thanks
Re: GT550 SRIS Oil Lines Correct Connection Squence
Not from the front! The left cylinder is on your left side when you're sitting on the bike!!
Great, thanks for that. I did wonder the same thing myself, cheers
