T500 bogged down when idling
Posted: Fri Apr 28, 2017 2:00 pm
by PippiFyrecracker
anyone else have this issue, or have an idea what it could be? I'm trying to work out the bugs on my bike.
it idles OK when cold, but after a couple km, when I'm stuck at a light, even in neutral, i have to rev the throttle a bit so it doesnt stall, the longer I'm sitting there, the worse it gets...my idle is at about 1.5...
Re: T500 bogged down when idling
Posted: Fri Apr 28, 2017 3:23 pm
by PippiFyrecracker
I have some air in the oil lines farthest from the pump... maybe this could be the issue?
Posted: Sun Apr 30, 2017 2:43 pm
by titan performance
I doubt the oil line issue is anything to do with it....though you need to address that sooner than later.....is the bike in stock trim?
Posted: Mon May 08, 2017 8:04 pm
by PippiFyrecracker
stock trim? as in? please clarify... thanks
Posted: Sat May 13, 2017 7:06 am
by MECH770
Has the bike got standard exhausts, air filter, Overbore on the engine etc.?
Posted: Fri Apr 05, 2019 12:45 pm
by PippiFyrecracker
fixed the oil issue but no change, other than no more air in lines, yes its stock
Posted: Sun Apr 07, 2019 3:09 pm
Have you tried adjusting the mixture screws at all?
