Both Heads have a crack running from the plug holes.
This is the worse of the 2.
Any issues with welding?
GT500 Cracked Heads
GT500 Cracked Heads
GSXR 750 L4 and K2 for the Track
GT500
GT500
Re: GT500 Cracked Heads
Hi Richard,
It has been a common practice to fill the combustion chamber with weld and then to re-machine to create centre plug heads with a proper squish band so if done correctly welding up a crack should be no problem. The hard part is to find a competent alloy welder who knows how to weld M/C parts and can re-machine the heads afterwards.
I know a motorcycle race engineer in Doncaster who could do the job (he could also convert them to centre plug ) or alternatively seek out a pair of replacement T/GT heads.
Cheers Geoff
Cheers Geoff
Cheers Geoff, looking closer can see it's run up the threads through the head.
Already spent a bit so might as well get some heads and get proper repairs if needed.
Heads are going around £50 each I can see but not sure!
GT500
GT500
Hi Richard,
They could still be repaired, and a good opportunity to make them into race heads at the same time . However I think sourcing replacement heads is the best way to go, £50/each is a realistic price. I might have a spare pair myself but I will have to check, gave a set away to a friend a while back so not totally sure.
Cheers Geoff
Cheers Geoff
Hey could you give me contact details of the motorcycle race engineer in Doncaster who could do the job?
Would me much appreciated Geoff.
The only heads I've seen are on eBay so couldn't know if they are suffering too.
GT500
GT500
