Does anybody have the T500 part no. for..
Posted: Fri Aug 26, 2016 12:02 pm
by tricky1962
The grommet that protects the blue neutral switch wire between the sprocket cover and the alternator cover?
Sorry for the inane question, but I can't see it anywhere and as I'm shopping for parts would like to include it.
It must be a simple half circle grommet but..
Re: Does anybody have the T500 part no. for..
Posted: Fri Aug 26, 2016 1:41 pm
by Jimroid
31485-15020
Posted: Fri Aug 26, 2016 1:59 pm
by tricky1962
Cheers, but correct me if I'm wrong. I think that is the grommet at 12 'o' clock for the wires from the generator.
I need the grommet at 3 'o' clock which solely feeds the blue wire from the neutral switch
Posted: Sat Aug 27, 2016 6:22 pm
by Jimroid
I'd have to pop the cover off to look,so not sure at this point.
Posted: Sun Aug 28, 2016 2:16 am
by tricky1962
The notch in the casing is just about visible here
http://www.ozebook.com/compendium/T500parts/image7.htm" onclick="window.open(this.href);return false;
but I am now thinking it is too small for a grommet. Maybe the insulation on the wire should be thicker at that point to protect the conductor?
