1974 T500 carb boots
Posted: Sat Aug 20, 2016 11:46 am
by RossB
My 74 T500 carb (To manifold) boots are hard as a rock,going break down buy some new ones
Any suggestions for best fit for aftermarket? Titan makes them and Paul Miller has them too.
Thanks!
Re: 1974 T500 carb boots
Posted: Sat Aug 20, 2016 4:15 pm
by ConnerVT
Suzuki dealers should have them too.
Posted: Mon Aug 22, 2016 12:27 am
by titan performance
Ross,
If you are keeping the stock airbox, and therefore supporting the carbs at both ends, then after market boots are ok......however, if like me, you are using pod filters, then only the stock part is strong enough. They are costly, but readily available.
Posted: Mon Aug 22, 2016 2:51 pm
by Jimroid
I should have two good ones off my 75 sitting in the basement.
Posted: Mon Aug 22, 2016 7:32 pm
by RossB
Got a couple coming in from UK OEM takes forever, thanks for your help!
Posted: Thu Sep 08, 2016 4:57 am
by jerrygere
Greetings keepers and hopefully riders of old bikes. I have a 73 T500 since 1975. It's not a show piece by any stretch but always ready to go. In 41 years I have ridden it about 35,000 miles. I have replaced tires, cables, one set of chain and sprockets and a pile of points and condensers. also miscellaneous bits like clutch actuater under the left case and one carb to cylinder boot. That was maybe 10 plus years ago. Knowing my Suzuki dealer was far away and out of stock I went to local auto parts store and bought a foot of reinforced radiator hose of appropriate diameter. The boot is about 2-1/2" long so I have enough material for at least 3 more boots. I know it isn't right but it does work. I have been running pod filters for 20 years or so after I got tired of fighting with air box to carb boot.
Posted: Thu Sep 08, 2016 5:53 am
by Zunspec4
Motocarb, in the UK, have a direct replacement for the T/GT 500 carb to head boot. A good outfit, I have bought various carb parts from them.
http://www.motocarb.com/adapters--connectors.html
