Just checking to see if there is any advice on this big bore 2 stroke carb bucking issue at deceleration? I've read up on the issue some and I understand that I should adjust pilot air screw up or down to see if I am running too lean or rich.
Ivan mentioned going up to a #35 pilot jet. I do not see that item # listed in my sources. Has anyone had success with this modification from standard #30. Does anyone have the #35 pilot jet item # so that I can do a search if needed?
Last but not least, does anyone else want to throw out an idea on this? Thank you LP
T500 Carb Bucking issue
1970 Suzuki T500 Titan Twin
1971 Yamaha HS1B 90cc Twin
- Country: us
- Suzuki 2-Strokes: GT
Re: T500 Carb Bucking issue
On my 76 GT500,I had severe bucking when decelerating and slow speed,turned air screw out to lean out,ran much better.On my 73 GT750 I turned air screw in to richen mixer to solve issue.
- ConnerVT
- Novice racer
They are sized in 2.5 step increments, so you can go up to 32.5 first.
VM22/210-32.5
VM22/210-35
VM22/210-32.5
VM22/210-35
Ivan was right......fit a 35 and it will be cured !
Once I fit a 35 will there be other adjustments, of a non traditional specification, that I will need to make with the pilot and throttle screws? Thank you gentlemen.
Mine was running a bit lean, when I turned in the screw a 1/4 the bucking ceased. Thanks for the advice. LM
