T500 oil seals
greens888
Suzuki 2-Strokes: 74 T500 74Re5 74Mach111
T500 oil seals
Post by greens888 »
Hi, have identified that my right oil seal seems to have gone, have crank out, how do you change the outer oil seals? Can`t work out how it comes out. 74 model. Actually the left and right seals look really good from the outside, only seem a bit weak around the shaft, which is obviously the critical point. They`re hardish but look intact. The bearings seem perfect so it`s a shame to have the crank redone as my understanding is that they wreck the bearings splitting the crank. The only thing not perfect looking is the 2 `o` rings on the centre bearing housing. They have a few nicks on them. Can you do the outer seals without splitting the crank. Steve.
old racer
Country: Wales
Suzuki 2-Strokes: RG250 GT750L GT750 DRAG seelyt500 tr500MK3
Re: T500 oil seals
Post by old racer »
The outer right left seals just pull off.
To replace the inner crank seals you need to strip the crank.
If you have the crank out then it's a good time to rebuild it and have a reliable motor,
Because they probably need changing.
greens888
Re: T500 oil seals
Post by greens888 »
Great, thanks for that.
