Might be a dumb question but is there a way to set the ignition timing without using a dial gauge indicator (and perhaps having to remove the tank?). Is it possible with a timing gun? Seems like not with no timing marks?
About to take the plunge and bite the bullet on buying a dial gauge but don't want to buy one and then find out there was an easier/better/cheaper way.
Thanks in advance!
BTW, my GT550 was converted to electronic ignition so at least I get to set it once for the left cylinder and be done with it. The bad news is that it wasn't installed by me and I don't know much about it. I have the installation manual that the previous owner had printed out but it doesn't say who it was manufactured by. It uses a Nordlock locking ring and has red lights that indicate the magnets on the timing disk are near the sensors if that sounds familiar to anyone?
GT550 set the ignition timing without a dial indicator?
- Suzuki 2-Strokes: GT550
Re: GT550 set the ignition timing without a dial indicator?
Never mind, I think I figured this electronic ignition out.
I popped off the cover and it turns out there are cylinder marks on a butterfly that you can see through a little window on the plate. It then makes perfect sense that you want the left cylinder light on the sensor to come on right at the moment the L mark aligns through the little hole and that's how I adjusted it. Will take a test ride in the morning.
- Country: WALES
I too have a 550 with electronic ignition. The rotor can be seen through the window L C R. I use a strobe light (very cheap) to set it. Simple process easy to do.
98 carb Blackbird and GT550j
The 'butterfly' timing marks are fine.
They're all I've ever used on 550s after I once used a dial gauge and found the marks were less than half a degree out.
These old engines aren't so high output that half a degree makes a difference.
Thanks guys. I feel reassured.
- Suzuki 2-Strokes: GT550, TS400
I've always used a piston stop and degree wheel to set my timing. I don't know if it's any more or less accurate than a dial indicator, but I already had the tools needed from my go-kart racing days.
By the way, thanks Alan for the Carrot Cycles link. The Newtronics ignition is in transit as we speak.
No probs.
Thought I'd report back that I took her for a ride this morning and the bike ran better than ever after setting the timing dead on. Go figure.
- Country: WALES
Happy days ☺
Coming late to this, but as said above, the L-C-R marks are usually so close to optimum timing as to make no difference.
On my old 380, I did actually check the marks using a dial gauge etc. The marks were about 3 degrees retarded from Suzuki's recommended setting. However, I got a tiny bit of detonation at the recommended setting, so I just started using the L-C-R marks with no further problems. The bike ran better.
