wet and dry
billy192
Suzuki 2-Strokes: T500 M. Honda CB750K6,CB500T76, Yamaha Vmax
wet and dry
Post by billy192 »
Just ran my T500 for 10 - 15 mins in the garage and the RH runs clean but the LH has a wet plug. Swapped the plugs and ran again and the same. Its as if the LH is not firing all the time. Will swap the coils tomorrow.
Could the mixture do this, the pilot is set the same and the float level and the Cir clip position.
Strange.
Billy
Suzuki T500 1975
Suzuki GT750 1974
CB 250G5 1975
CB 500T 1976
CB750 K6 1976
Kawasaki S3 1974
C90 1972
Triumph Tina 1964
Re: wet and dry
It could certainly be ignition. Take out the plugs, ground them and kick it over to see if both plugs spark. That would be my first step.
billy192
Re: wet and dry
Post by billy192 »
they both spark :(
Suzuki T500 1975
Suzuki GT750 1974
CB 250G5 1975
CB 500T 1976
CB750 K6 1976
Kawasaki S3 1974
C90 1972
Triumph Tina 1964
Re: wet and dry
Interesting, the left may be flooded. Hey, I just sent you a PM about the GT750L seat. I forgot all about it.
Re: wet and dry
Have you checked the ignition timing?
Re: wet and dry
They may spark fine when you test them by hand at atmospheric pressure.
That doesn’t guarantee they will spark with the short dwell time of a running engine & at pressure.
Make sure you have a fully charged battery.
Some twins (T250/T350/T500/GT250) will run fine without a battery.
Others won’t run right unless the battery has a good charge. Often one cylinder is OK & the other is problematic.
