Gt500 twist grip
Posted: Thu Feb 11, 2016 4:03 pm
by buzzer
Anyone help me? Just assembled my twist grip and i notice that there is no positive stop in the closed position. Am i missing some parts? Any of you guys got any pictures?
Re: Gt500 twist grip
Posted: Thu Feb 11, 2016 4:43 pm
by titan performance
Not sure what you mean Buzzer?
Posted: Thu Feb 11, 2016 5:01 pm
by buzzer
titan performance wrote:Not sure what you mean Buzzer?
Ok, i have had a few beers... Started the bike tonight, first time its run since 1986!
What i mean is, in the closed position, i can turn the twist grip clockwise, there does not apear to be a stop to prevent this, like on other bikes i have had. The twist grip was off the bike and in bits when i bought it, so i may be missing parts.
Posted: Fri Feb 12, 2016 12:18 am
by A.Holley
On. A lot of twist grips, the cable end piece that screws into the twist grip is the "stop" for the drum.
If you don't screw the cable end pice in fa me not ugh it won't perform this function.
Hope this helps
Andrew
Posted: Fri Feb 12, 2016 12:19 am
by A.Holley
Damn I pad keyboard,
Should have read, if you don't screw it in far enough.
Andrew
Posted: Fri Feb 12, 2016 7:54 am
by buzzer
A.Holley wrote:Damn I pad keyboard,
Andrew
Thanks Andrew. I had hope when I read this... but no, it was screwed right in... looking at it, i am beginning to wonder if the case / twist grip part is off another bike? the engine kill switch works opposite to how it should as well... anyone any ideas?
Posted: Fri Feb 12, 2016 1:26 pm
That's not the proper throttle tube, which is why it doesn't stop !
Posted: Sat Feb 13, 2016 4:17 am
by buzzer
titan performance wrote:That's not the proper throttle tube, which is why it doesn't stop !
Dam... Looks like I will have to get a new one
Posted: Sat Feb 13, 2016 1:41 pm
by buzzer
I took a look at the one I have, and one on the web... and thought I can make that... so I made one out of brass and silver soldered it on the tube. works a treat and feels much better, and has a positive stop.
thanks guys.
