flasher relay
Posted: Sat Apr 18, 2009 4:01 pm
by A-Dubs
I'm having a similar problem to jaybob in the LED thread in that I installed new single filament bulbs in my GT500 and am getting steady light rather than blinking. seeing how that thread has moved on from the relay point I thought it'd be best to start a new one.
the electrical side of things is newer to me, so where should I be looking to pick up a new relay and/or would the one mentioned in the LED thread work? and even more basic, where on the bike is the original found? I poked around and compared back and forth to the parts catalog and am feeling somewhat foolish as I'm not sure what I'm looking for.
Posted: Sat Apr 18, 2009 4:06 pm
by Odin
its usually located by the oil tank mounted to the frame and is cylinder shaped,
I have used 2 pin 12volt flasher relay's from walmart and they work fine.
have you checked to see that everything is grounded properly first?
Posted: Sun Apr 19, 2009 1:12 am
by jaybob
Auto parts stores have the relays also. I used the one form superbright LEDs and it works good also.
relay
Posted: Mon Apr 20, 2009 9:20 am
by rbond
As much as I hate to, remove the seat and look at the rectifier. Just to the left of it using the same mounting bolt is a round can with a two wire lead. That is you turn signal relay. Loosen the bolt and it should slip out of the strap holding it.
Posted: Mon Apr 20, 2009 2:42 pm
by A-Dubs
thanks: found the location on the bike yesterday, just wasn't looking in the right spot and felt even more foolish once I realized it was under my nose the whole time.
