Page 1 of 2
First restoration: GT550. Advice welcome
Posted: Wed Sep 23, 2015 11:38 am
by capazzo22
Hey everyone! I'm new to the boards here and new to restoring bikes. I've had a lot of experience working on cars out of necessity, and am somewhat mechanically inclined. I've always wanted to get into restoring old vehicles and I found an old GT 550 in my grandpas barn, figured this is as good a place to start as any.
I believe my bike is 1975. It says 8/74 as manufacture date and lists the vin as gt550-49739 so I think that puts me in the model M category of 1975. The license plate on it says 1988 so I at least know it was last running about 27 years ago!
Anyway, I have no clue where to even start on this bike. I've got a clymer manual and I was thinking of using that to guide me on the "how to", but I'm not sure where to start. Any advice or pointers would be most welcome. Thanks in advance!
Photos to come once I figure out how to post them. Ha ha
Re: First restoration: GT550. Advice welcome
Posted: Wed Sep 23, 2015 11:46 am
by titan performance
We all have different opinions on this.....but for me, I would want to get it running first....if the engine is blown to bits you may feel it's not worth the bother.
Posted: Wed Sep 23, 2015 11:54 am
by capazzo22
titan performance wrote:We all have different opinions on this.....but for me, I would want to get it running first....if the engine is blown to bits you may feel it's not worth the bother.
Ok, that's kind of what I was thinking too. Get it running first. My question is should I start by rebuilding the carbs? It looks like there was some leaking from some engine seals so should I start by pulling that apart, cleaning and redoing seals?
Posted: Wed Sep 23, 2015 12:43 pm
by GTandcbr
Welcome to the forum I think the first question is the motor stuck or free. If it is free I would start with the carbs and cleaning the petrol tank. Flush out old petrol . take out the plugs and before cleaning them have a look they may give you an idea how the bike was running before it was stored. Lots of help on here! Good luck
Posted: Wed Sep 23, 2015 2:03 pm
by capazzo22
GTandcbr wrote:Welcome to the forum I think the first question is the motor stuck or free. If it is free I would start with the carbs and cleaning the petrol tank. Flush out old petrol . take out the plugs and before cleaning them have a look they may give you an idea how the bike was running before it was stored. Lots of help on here! Good luck
Great! Thanks for the encouragement and advice. I think the engine turns since the chain was moving just fine. I guess it could have been in neutral, but I'll check that out first.
Posted: Thu Sep 24, 2015 4:49 am
by rngdng
My advice to you is to start drinking heavily. Where was that bike buried anyway? Step on the kicker and see if it turns over, the chain moving probably means it's in neutral. If you decide to restore it, just prepare yourself for a tedious and costly project. BUT, if you plan on keeping it, it can also be a rewarding project.
Posted: Thu Sep 24, 2015 8:54 am
by capazzo22
rngdng wrote:My advice to you is to start drinking heavily. Where was that bike buried anyway? Step on the kicker and see if it turns over, the chain moving probably means it's in neutral. If you decide to restore it, just prepare yourself for a tedious and costly project. BUT, if you plan on keeping it, it can also be a rewarding project.
It was sitting in my grandpas barn so not really out in the weather, although it does kind of look like it was actually buried. Oregon is pretty humid.
Yeah, I'm planning on restoring it for myself, and definitely not for any sort of profit.
Posted: Thu Sep 24, 2015 9:31 am
by ConnerVT
That's good. The best way to make a small fortune restoring motorcycles is to start with a large fortune.
Posted: Fri Sep 25, 2015 6:58 am
by buffalodave
Invest in a LOT of EVAPORUST... you'd be surprised how good that stuff is for cleaning all sorts of parts and chrome...
But I'd make sure it spins over freely. Just remember that you SHOULD be doing this for enjoyment and to keep yourself out of the local watering holes...Me personally I am a GLUTTON for punishment and would probably want to do it... How are the body parts?
Posted: Fri Sep 25, 2015 7:04 am
by Bloop2
Looks like the Cobra that I'm just about finished restoring, same shape. You just need deep pockets and don't worry about the cost.
Posted: Fri Sep 25, 2015 7:07 am
by ConnerVT
Bloop2 wrote:Looks like the Cobra that I'm just about finished restoring, same shape. I have deep pockets and don't worry about the cost. I'll help you out.
Fixed it for you.
Posted: Fri Sep 25, 2015 7:18 am
by Bloop2
Thanks for fixing that
! I have special pair of work shop pants where the pockets reach down to the knees. So far I haven't reached the bottom, but getting close.
Posted: Sun Sep 27, 2015 1:07 pm
Before you try to start it, lift the barrels off and remove the pistons from the rods, then fill each crankcase with diesel. Turn the engine over slowly on the kicker - lots - then drain/refill/repeat.
This will soften the seals and get a load of crap out of the bottom end of the engine. Make sure all oilways are clear, then use an oil gun to squirt some oil down all the pipes from the oil pump to the engine. Clean the carbs. Then do it again as the first time won't be good enough. Then refit the pistons, barrels and heads and try to start it. You need a GOOD 12v battery and good wiring connections at the very least.
Plenty of advice regards 550s on here, I'm on my 3rd and several more in reserve!
Posted: Sun Sep 27, 2015 2:07 pm
by capazzo22
Alan H wrote:Before you try to start it, lift the barrels off and remove the pistons from the rods, then fill each crankcase with diesel. Turn the engine over slowly on the kicker - lots - then drain/refill/repeat.
Thanks for those tips! That's exactly the kind of stuff I'm looking for.
I'm planning on replacing the wiring before getting to the starting point. Just got the carbs off so I will start on those soon. I will need some hard work to get the head cover off as two bolts snapped below the surface with almost no torque on my part. My first try to get one out had my easy out snap off in the bolt. Funny part is when I took the mufflers off they came off super easy. That's funny to me since when I work on cars the exhaust manifold is almost always the must stuck on part.
Good news is the mufflers sound solid, no rattling or loose crap inside!
Posted: Sun Sep 27, 2015 3:43 pm
by Cliff
Great pics of the bike! Don't mean to hijack the thread, but can anyone tell me what those two bolts are for in the frame behind the rear brake light switch?? Every GT550 I've seen, including mine has them!
Cliff!!
