Angled pod filters for GT380/GT550?
Posted: Tue Aug 25, 2015 10:51 am
Is there any benefit/penalty for using an angled pod filter? (resonance?)
In particular, have a 72 project GT380J.
The regular cone pod filters don’t clear the oil pump cover, which is presumably why they list them for all-year GT550s & only later-year GT380s.
(I've seen regular cone pod filters that owners have dented to clear the cover.)
I think one of these angled filters might clear.
K&N 43mm 40-degree pod filter, R-1100 (similar to the RC-1070 which they recommend for later-year GT380s)
eBay Chinese? 42mm 45-degree filter (Chinese?)
http://www.ebay.com/itm/42mm-Cone-Short ... 1558126209
42mm 90-degree scooter filter
http://www.scooterpartsexpress.com/stan ... her-models
Re: Angled pod filters for GT380/GT550?
Posted: Fri Aug 28, 2015 10:18 am
I bought one of the K&N filter to see if it would work.
Here is a test-fit pic.
The filter is rotated a bit to clear the frame.
I don’t have the oil pump covers — looks like some cover mods may be needed.
Posted: Fri Aug 28, 2015 3:25 pm
by Coyote
I almost thought that was RedZone when I saw the frame color. :shock:
Posted: Fri Aug 28, 2015 6:28 pm
by bill in okc
I bought a spare oil pump cover on ebay and modified it to clear the right pod filter. I do not ride it enough to worry about dust/dirt getting into the oil pump area.
Posted: Fri Aug 28, 2015 7:46 pm
by Coyote
I'm lazy and cheap. I just crease the pod to clear. As a matter of fact I did that just 3 days ago. I found some really cheap pods on eBay. Like $5.87 each and free ship. I might run these - for a while anyway. These are kinda cool as they are longer than most others. Notice I don't even have the clamps on yet. Just trying to get it to butt up against the stops - top and bottom, and be even with the other 2. That white spot on the end cap is assembly glue. Scrapes off easily.
Posted: Sat Aug 29, 2015 4:02 am
Its a GT380J. Motor is smaller than the GT550’s & has less room for the pod filters. Had the cheapie pod filters on it when I got it. The pump control mechanism was rubbing up against the filter & starting to make a hole in the filter.
The bike is a future project & I’m just collecting parts for it.
Purchased only 1 angled filter to see how it would work out.
A PO painted the frame & turned it into a brat bike.
I’m going to turn in into a cafe but it won’t be as neato as RedZone.
Bike is red & I’m probably going to paint the side covers black.
Also thinking about switching to a GT750 4LS front brake.
Posted: Sat Aug 29, 2015 4:34 am
by ConnerVT
jabcb wrote: Also thinking about switching to a GT750 4LS front brake.
Seems that would be a lot of unsprung weight on the front of a GT380.
Posted: Sat Aug 29, 2015 6:26 am
I don’t know what Suzuki was thinking at the time.
The GT380 is just about the same weight as the T500, but Suzuki initially used the lesser front brake from the T250/T350.
A few years ago I got a 4LS brake for use on a T500.
My post about using it on that bike generated forum disagreements.
Some people have done it & are satisfied with the results, while others say it will turn out badly.
I expect the 4LS to work better on the GT380 than the T500 due to its better suspension.
But I could be wrong.
Posted: Sun Aug 30, 2015 5:37 pm
The GT550/750J 4ls front brake is excellent.
Takes a bit of setting up and keeping up with, but a bloody good brake.
If you have the knowledge, just double up on a front disc, but if you really want to stop in all weathers, the 4ls is the way to go.
Maybe a bit ott and expensive for street use on a 380?
Posted: Mon Aug 31, 2015 4:01 am
The GT380J has a 2LS front brake that was taken from the T250/T350, which are a good bit lighter.
The T500 has a larger 2LS front brake & is about the same weight as the GT380J.
I remember the GT380J reviewers complaining about the brake back in 72.
I happen to have a 4LS front brake + wheel, NOS cables & NOS brake lever assembly.
So the upgrade won’t cost much but then I’m loosing out on a nice $$$ eBay sale for the parts.
Posted: Mon Aug 31, 2015 7:10 am
by Coyote
Give me a simple disc any day. Way fewer moving parts (the caliper piston) and no complex cabling. Not to mention it's lighter plus pretty much maintenance free.. Pads are cheap and discs are plentiful. If the caliper is free on the pins and the pads have meat, you're good to go. You do have to contend with that ugly MC sitting on the handlebars but hey, nothing is perfect. I've seen a few girls that came close, but then they opened their mouth :P
