Gt185 race project ignition ?
Posted: Mon Jul 06, 2015 8:02 am
by S.McCain
Want to to know if the gt250 and 185 are interchangeable? Pvl makes one for the
250.
Thanks!
Re: Gt185 race project ignition ?
Posted: Tue Jul 07, 2015 4:00 am
by S.McCain
25 views and no response..
Can anyone recommend someone that may know?
Posted: Tue Jul 07, 2015 6:06 am
I would expect that you might have to get an adapter plate machined to fit the stator, but I would expect it to be able to be fitted with a little work. Check the taper and I can compare that to a TZ which is the same as a GT250.
Try the importers Penton in Ohio.
Posted: Tue Jul 07, 2015 8:08 am
by S.McCain
tz375 wrote:I would expect that you might have to get an adapter plate machined to fit the stator, but I would expect it to be able to be fitted with a little work. Check the taper and I can compare that to a TZ which is the same as a GT250.
I'm really spoiled with Yamaha's..several options there.
Posted: Tue Jul 07, 2015 11:28 am
I have a PVL that was fitted to a GT750 and it is now on a Yamaha motor. If you have a Motoplat or FEMSA or HITACHI for a Yamaha RD/TZ twin, compare it and see what changes need to be made to the backing plate (if any).
I have a Motoplat here that has never been fitted to a bike complete with TZ mounting ring and coils. I also have one for a T500 with a larger crank nose.
