On The FLOOR!
Posted: Mon Mar 09, 2015 7:26 am
by Coyote
After 6 months on the maintenance stand, the bike is finally on the floor. Suddenly, it looks dinky. Kinda like a low rider
Now comes the treat of
TRYING to hang the exhausts. I bought new clamps and rubbers for the center junction. I wish I had kept the old rubbers. These new ones are super tight. So tight in fact I may never get the pipes on. I have to stretch them to get them on the header pipe. When I do that, it forces the larger end to fold / tuck in on a hole that is already too small. Is there a trick? I thought maybe I got the wrong ones, but the part number for the 380 is the same. P.S. the block of wood on the head means nothing.
Re: On The FLOOR!
Posted: Mon Mar 09, 2015 11:30 am
by Craig380
Looking good!
Re: On The FLOOR!
Posted: Mon Mar 09, 2015 3:06 pm
by pearljam724
Try heating them with a blow drier. Before they cool off, hit the insides with a lubricant. A lubricant that will dry away. WD-40 for example.
Re: On The FLOOR!
Posted: Mon Mar 09, 2015 4:16 pm
by GT750Battleship
Hi,the trick is to fit the rubbers to the exhausts..not the header pipe ! spray with something like WD40 or the like & it won't be a problem,works every time on my 750
I'm sure this fitment method is mentioned in my Haynes manual
OR you're try to put them on the pipe the wrong way round
Re: On The FLOOR!
Posted: Mon Mar 09, 2015 5:20 pm
by Cliff
Put the rubbers/clamps on the center mufflers first then slide them onto the header pipe. Might need a bit of lube on the ID of the small end. Snug up the bolts on the center pipe where it bolts to the cylinder first. That will hold the header in place and you can work the mufflers on.
She's starting to look like a bike again! Nice work!!
Re: On The FLOOR!
Posted: Mon Mar 09, 2015 6:05 pm
by Coyote
Anybody ever tried flipping the bike over to do the job? I've been toying with that idea in my feeble mind.. I have filled the transmission, but if the o-ring on the cap is good and I cap off the breather pipe--------hmmm. Oil tank and brake hydraulics are still dry.
Re: On The FLOOR!
Posted: Tue Mar 10, 2015 4:25 am
by GT750Battleship
Re:c On The FLOOR!
Posted: Tue Mar 10, 2015 4:55 am
I got my exhausts together by putting a load strap around all 3 and ratcheting them together. Plenty of lube on the O rings.
Re: Re:c On The FLOOR!
Posted: Tue Mar 10, 2015 5:39 am
by rngdng
Alan H wrote:I got my exhausts together by putting a load strap around all 3 and ratcheting them together. Plenty of lube on the O rings.
I've done the same thing. I lubricate the o-rings with three-bond which helps the sealing as well.
