Clutch Noise
Tripleking
Suzuki 2-Strokes: GT380, T250, GSX750F
Clutch Noise
Post by Tripleking »
Back over the summer there was a post about a gearbox noise that went away when the clutch lever was squeezed. I cannot find the post. I have a similar problem on my 71 T250 with 73 GT250 engine. If someone can point me to the post or give me some insight I would me most appreciative.
Re: Clutch Noise
I didn't look for the old post but I would expect such a noise to be down to the bearing that the clutch drum runs on!
Tripleking
Re: Clutch Noise
Only makes noise in neutral. I have to look at the schematic, but I hope I don't need to open the case. I just rebuilt it in 2013.
Re: Clutch Noise
Not the same animal but my GS1000 has been doing that for 20 years. No ill effects.
lrutt
Re: Clutch Noise
Post by lrutt »
My 70 does the same thing. I figure if it gets worse or I have to tear down for some other reason I'll check it out. but for now, it runs and works just fine and is not getting any worse.
2004 HD 1200C
2001 Duc M900
2001 Hon XR650L
1994 HD Heritage
1978 Hon CB750 w/ sidecar
1977 Guzzi 850 LeMans
1976 Hon CB750K
1965 Hon 305
1973 Nort 850
1971 Tri Trophy 650
1970 Hon CT 90
1970 Tri Tiger 650
1970 Suz T250
1973 Hon Z50
1971 Yam RT1
Re: Clutch Noise
For a description of the problem & the fix, see service bulletin General-15:
http://www.ozebook.com/compendium/techb ... 010-18.pdf
Tripleking
Re: Clutch Noise
Brilliant. I have been running oil which is too thin. I am going to try that first as it is the easiest fix among the possible causes and take it from there. I have bookmarked the page. Thx!!!
Vintageman
Re: Clutch Noise
Post by Vintageman »
With respect to the bulletin reference in a previous, which I have done, the next time I bought a new clutch bushing (the thing the bulletin says to sand shorter) ,maybe a year or two ago, from Suz and to my surprise it came with the thrust washer machined with it... where as before it was two separate pieces. For me that new part, when installed, took away the noise you describe.
Tripleking
Re: Clutch Noise
Running thicker oil (15W40) has made the noise all but disappear.
Re: Clutch Noise
I run 85wt gear lube in the transmissions.
