keystone piston rings but not in piston groove?
mikefealk
Country: usa
Suzuki 2-Strokes: 1974 gt 750 , 1965 80 cc
Post by mikefealk »
recieved 3 nos .5 over pistons and ring sets. i see the rings are tapered (keystone) as seen in manual. i also see in the manual picture that the grooves in the piston are also tapered to the same shape. well the ring grooves in these pistons appears square to the eye, not in the tapered shape. ??
Re: keystone piston rings but not in piston groove?
Take a piece of chewing gum (chewed) and press it in the groove. Pull it out to be sure it's tapered. Alternately you can use clay or melt some candle wax. To my ancient eyes, it's hard to see the taper on the rings not to mention the pistons.
OR. You can install a ring and squeeze it. It won't go flush go if the groove in the piston is straight. Don't forget to align the ring over the pin.
mikefealk
Country: usa
Post by mikefealk »
good idea coyote. maybe im just not seeing it correctly. ill try that after work today.
Barry S.
Post by Barry S. »
The rings will go on only one way, if upside down taper will not fit piston.
2007 Suzuki V-Strom DL650
Pete O'Dell
Country: uk
Suzuki 2-Strokes: T500X2 GT500 GS750 GS500/4 KAWASAKI A1 GT250
Post by Pete O'Dell »
the size of the rings is usually marked on the upper surface of the ring, and round the wrong way they will not push into the groove
