water pump driven gear thrust washer
Posted: Thu Dec 04, 2014 8:14 pm
by mikefealk
in the fiche its very unclear. so there is an e ring on the outside of the bearing, then goes the washer, then gear, then another e ring? i think the washer is supposed to be on the outside of the plastic gear, but the gear will rub on the starter clutch if i do not use the washer on the inside of the gear. anyone?
