Replacement keys
Marshall
Suzuki 2-Strokes: Suzuki T350
Replacement keys
Post by Marshall »
Is there any way I can get a replacement key made if I have the number on the lock? My bike was assembled from a bunch of parts and it didn't come with a key.
Re: Replacement keys
ebay or Crooks Suzuki. Possibly any Suzuki dealer that does keys.
Fritz500
Post by Fritz500 »
There's a guy who sells them on eBay with the correct numbers stamped on them.
73 GT750 Ducati - 20%
72 T500J - 95%
09 Yam XVS950A
There are a few, here is one, who helpfully lists the #s of his used keys....
http://www.ebay.co.uk/itm/Suzuki-Pre-Cu ... 1c451c4536" onclick="window.open(this.href);return false;
I have checked that listing before as I am looking for key 151. One of the few missing from his list.
Quote the number to Crooks and they will do the biz. I have dealt with them since 1972 and they are very good.
http://www.crooks-suzuki.com/" onclick="window.open(this.href);return false;
Of course you could just put any key in there and file the detents flat if you don't want to spand! You will have to do all 3 locks though.
Paul Miller sells them in the USA, as does Reiner in Germany, Crooks in the UK - lots of options depending on your location. 8)
Paul Miller has key 151 listed on eBay.
http://www.ebay.com/itm/SUZUKI-T500-TS2 ... 1244208030
Marshall
Post by Marshall »
I noticed that the key codes have only 3 digits, while my lock has 5 digits.
If I have key 33324, what is my key code?
If that 5 digit code is stamped on your lock and it is original Suzuki, I believe this means you have an early, single-sided key lock. Please see Ian's page below.
http://www.oldjapanesebikes.com/GT750_f ... de/page-72" onclick="window.open(this.href);return false;
"The ignition key used a 5 digit code, and was one sided, unlike the double sided 3 digit coded keys introduced in 1974".
yeadon_m wrote:I believe this means you have an early, single-sided key lock.
Correct - pre 1974 model. 8)
Marshall
Post by Marshall »
Yes, mine is a 1972 T350.
So am I out of luck then?
No. I had some made for a '72 550 by quoting the number.
This eBay seller has key # 33324:
http://www.ebay.com/itm/Suzuki-Pre-Cut- ... 1301324299
His pic shows that the 3XXXX series keys are single sided, and 1XX series are double sided.
One of my older Suzukis has a single-sided key with the number 22.
Tried to get a duplicate.
Turned out 22 didn't refer to the number for the cut key, but it referred to the number for the blank uncut key.
Marshall
Post by Marshall »
Thanks, I just ordered that key now.
