GT550 clutch cover removal
Guys, I can't remember. Is one of the clutch cover screws behind the points plate? The fiche does not show one.
Re: GT550 clutch cover removal
There isnt anything about it http://www.oldjapanesebikes.com/mraxl_G ... 50-22.html" onclick="window.open(this.href);return false;
While the GT380 has two fasteners under the points plate, I don't recall a similar arrangement on the 550.
Does the parts diagram for the 380 show the two fasteners?
yeadon_m wrote:While the GT380 has two fasteners under the points plate, I don't recall a similar arrangement on the 550.
Yep it does remind you to remove the 2 behind the plate http://www.oldjapanesebikes.com/mraxl_G ... index.html" onclick="window.open(this.href);return false;
Cliff
Post by Cliff »
No, nothing under the points plate on the 550, just the bolts around the outside of the clutch cover. The cover does sit on two dowels though. If after removing the bolts the cover is still tight you'll have to gently pry it off the dowels/gasket.
