GT185 fuel/air questions
Posted: Fri May 02, 2014 9:42 pm
First off, my name is Mark. I am new to the GT's but happy to have one. I hate my 1st post is a question, but I'm at the last straw. Sorry, but here goes.
Trying to get an old 185 back on the road. Its a '74 with 1400 original miles. Its by no means a show bike, but it is pretty clean.
I am stuck and need help. What is choke on/off?? On = Up? On = Down?
(When I say 'choke up,' I mean choke lever in the upward position, and visa versa)
Symptoms:
-Bike runs and starts choke up or choke down, but on one cylinder.
-Choke up = right cyl firing fine, left is dead
-Choke down = left cyl firing, right dead
-Minor adjustments to throttle stop (with choke down) has yielded both cyls run (not sync'd but at least both firing) then the bike slowly fades off and dies.
-I can flip the choke while its running and get it to switch firing cyl.
-side note: I have been tinkering a little here and there, and one time, one time, it ran fantastic. It was peppy, it was sharp, and apparently it was an accident, because nothing was right. Carbs were off, tank was dirty, no fuel filter, choke lever in down position, cold night, late, dark, and angry neighbors. BUT it made one super lap around the neighborhood, and I loved it.
Things I have done:
-Check fuel, installed a clean clear in-line fuel filter and new hoses. Clear filter lets me visually see fuel flowing.
-Petcock is in rough shape. I took it apart, cleaned it and made it have steady fuel flow on reserve position (I know this is wrong, but its a solid flow, and that's what I am working with. Flow is weak in the on position)
-Exhaust baffles removed, 2 stroke wrap material added, and baffles reinstalled
-degreased gunk from tank, looks like its been coated, but its not real good. the filter helps me monitor and see fuel is as clean as can be with this setup.
-I have taken off the carbs, cleaned an re assembled. twice. new float bowl gaskets. Floats adjusted. Carbs dipped, anything rubber went into a rubber friendly dip.
-New exhaust header gaskets, old ones were leaking and allowing large amounts of 2 stroke oil to run down the pipe and eventually drip off about the foot pegs, messy.
-Bike run with tank cap on and off and in the 'loose' position. no difference noted in any option
-Terrible ground in the wiring loom. Replaced the ground, visually checked wires that next to the melted ground.
-New air filters (I only thought there was one, apparently there are two?? One on each side of the box?)
-new plugs, twice.
-pilot screws set at 1 turn out. Not messed with after that. I need it to start and run before fine tuning.
-throttle stop screws, This is where I am all over the board trying to get it right.
-set throttle cables at each carb to be close to 1 mm play
-adjusted oil pump cable after adjusting throttle stop cables
Again, I am sorry its typical newb 1st post.
Symptoms:
Things I have done:
-new plugs, twice.
