Page 1 of 2
Stuck in neutral, GT750
Posted: Sun Apr 20, 2014 11:06 am
by lasse
Hi!
I have a new to me GT750, where I just had it started up for the first time today. It was all great, besides the fact that I couldn't get it out of neutral.
I have no chain on the bike at this moment. How to proceed? Can it be an incorrect bolt in the neutral selector or something like that?
Re: Stuck in neutral, GT750
Posted: Sun Apr 20, 2014 12:27 pm
by titan performance
Has the bike been unused for some time?
Posted: Sun Apr 20, 2014 1:09 pm
by lasse
titan performance wrote:Has the bike been unused for some time?
Yeah 5 Years plus
Posted: Sun Apr 20, 2014 11:43 pm
by lasse
https://www.youtube.com/watch?v=geG5ug3 ... e=youtu.be" onclick="window.open(this.href);return false;
Video of the bike running!
Posted: Mon Apr 21, 2014 1:16 am
Looks like you have a little work on your hands there Lasse !
The clutch plates are probably stuck together....
Posted: Mon Apr 21, 2014 2:38 am
by lasse
titan performance wrote:Looks like you have a little work on your hands there Lasse !
But it should still shift gears, where the clutch is pulled or not?
Posted: Mon Apr 21, 2014 2:46 am
by Suzukidave
Some interesting things on your GT .. looks like a Power Dynamo charging / ignition system and a strange custom 3 into 1 exhaust system ? Hopefully you will be able to find neu when you get a chain on her .
Posted: Mon Apr 21, 2014 2:53 am
by lasse
Suzukidave wrote:Some interesting things on your GT .. looks like a Power Dynamo charging / ignition system and a strange custom 3 into 1 exhaust system ? Hopefully you will be able to find neu when you get a chain on her .
I put on the powerdynamo system, absolutely lovely! Runs without a battery. A Dresda swingarm too by the looks? I have bought some 3-3s for it :)
Posted: Mon Apr 21, 2014 3:10 am
As Dave said....I think you need to get the chain back on, as without it you can't move the transmission. Once it's on, the bike can be rocked back and forth as you press the pedal.....I wouldn't mind betting it will click in once you do that.
Posted: Mon Apr 21, 2014 1:45 pm
by lasse
How do you guys think the engine sounds?
Posted: Mon Apr 21, 2014 4:33 pm
by Blokhead
lasse wrote:How do you guys think the engine sounds?
Sounds a little noisy for a water cooled 2-stroke to me. Got water in it?
Without putting a stethoscope on it, I'd guess rod main bearings.
Posted: Mon Apr 21, 2014 6:44 pm
by Suzukidave
Its kinda hard to make a call right now .. get it running and idling steady and ask the question again :up:
Posted: Tue Apr 22, 2014 11:40 am
It's hard to tell from a vid...but these engines were fairly quiet, ie free from mechanical noises, and yours sounds rough to me.
Posted: Tue Apr 22, 2014 12:03 pm
by lasse
I tried to remove the gearindicator switch, couldn't move anything.
Gearselectorbolt was loose and the ball was missing. PO must have known something.
Took off clutchcover to try and select something, which also didn't work.
Posted: Tue Apr 22, 2014 1:20 pm
by dyrberg123
Hi Lasse, congrats on your new toy! :up:
Where in the country of Denmark are you located? I live in Vejle, maybe we could Exchange numbers, as we aren't many Young two stroke heads here.
What are your plans for the bike?
Cheers Daniel
