Stuck in neutral, GT750
lasse
Post by lasse »
Hi!
I have a new to me GT750, where I just had it started up for the first time today. It was all great, besides the fact that I couldn't get it out of neutral.
I have no chain on the bike at this moment. How to proceed? Can it be an incorrect bolt in the neutral selector or something like that?
Re: Stuck in neutral, GT750
Has the bike been unused for some time?
lasse
Post by lasse »
titan performance wrote:Has the bike been unused for some time?
Yeah 5 Years plus
lasse
Post by lasse »
https://www.youtube.com/watch?v=geG5ug3 ... e=youtu.be" onclick="window.open(this.href);return false;
Video of the bike running!
Looks like you have a little work on your hands there Lasse !
The clutch plates are probably stuck together....
lasse
Post by lasse »
titan performance wrote:Looks like you have a little work on your hands there Lasse !
But it should still shift gears, where the clutch is pulled or not?
Some interesting things on your GT .. looks like a Power Dynamo charging / ignition system and a strange custom 3 into 1 exhaust system ? Hopefully you will be able to find neu when you get a chain on her .
lasse
Post by lasse »
Suzukidave wrote:Some interesting things on your GT .. looks like a Power Dynamo charging / ignition system and a strange custom 3 into 1 exhaust system ? Hopefully you will be able to find neu when you get a chain on her .
I put on the powerdynamo system, absolutely lovely! Runs without a battery. A Dresda swingarm too by the looks? I have bought some 3-3s for it :)
As Dave said....I think you need to get the chain back on, as without it you can't move the transmission. Once it's on, the bike can be rocked back and forth as you press the pedal.....I wouldn't mind betting it will click in once you do that.
lasse
Post by lasse »
How do you guys think the engine sounds?
Blokhead
Suzuki 2-Strokes: GT750
Post by Blokhead »
lasse wrote:How do you guys think the engine sounds?
Sounds a little noisy for a water cooled 2-stroke to me. Got water in it?
Without putting a stethoscope on it, I'd guess rod main bearings.
'79 KZ650SR w/162hp Polaris XC700 Snowmobile Engine Dragbike
'73 GT750
'74 H2 750
'90 GSXR 1100
'75 H1 500
'76 KH400
'76 RD400
Minitrail 50
2 Trizingers
Its kinda hard to make a call right now .. get it running and idling steady and ask the question again :up:
It's hard to tell from a vid...but these engines were fairly quiet, ie free from mechanical noises, and yours sounds rough to me.
lasse
Post by lasse »
I tried to remove the gearindicator switch, couldn't move anything.
Gearselectorbolt was loose and the ball was missing. PO must have known something.
Took off clutchcover to try and select something, which also didn't work.
dyrberg123
Country: Denmark
Suzuki 2-Strokes: T350 GT750 T125 RG250 RD125lc RD350lc RD400
Post by dyrberg123 »
Hi Lasse, congrats on your new toy! :up:
Where in the country of Denmark are you located? I live in Vejle, maybe we could Exchange numbers, as we aren't many Young two stroke heads here.
What are your plans for the bike?
Cheers Daniel
If it's not broken - don't fix it. Why not?
