A couple of questions........
Re: A couple of questions........
One of my other customs i also ran into problems similar to yours so i also run the largest front sprocket and adjusted the rear sprocket and i also put on a roller wheel and a double set of sliders to keep the chain off the shifter shaft and swingarm pivot .
- garry55
hmmmmmmmm - thats neat!
I'll have another look at what I can fit in the casing - I like the roller idea (and the "S" marked bolt is classic)
Garry
The roller is a roller bearing skateboard wheel and its bolted to to a side cover screw hole . I had to open the size of the hole and tap for the bolt . The plate you see i also designed to contain the chain in case there was a break and direct it through and out the bottom instead of bunching up under the side cover .
Splines are the same - shape differs. Its covered in the Field Guide eh ?garry55 wrote:GT750 - do kickstart levers from later bikes fit the earlier J/K models?
Richard (teazer or tz375 depending on the board) put together a useful chart for gear ratios, RPM and MPH. HIs site seems to be down at the moment, but you can pull a copy from this link off my site.
Yes, have seen the chain pads on swing arms....Aprilia & the like....
Roger.
Gear shifter shafts also come in 2 different lengths and that can also come in handy .
