I think i would take a little ride on the bike before removing the old grips , get it up to a nice highway speed say 60~65 and mark on the grip right where the top of the grip is at that throttle setting . I would put the new grip on so that ridge would be right on top at that highway speed to give your hand a little break when you need it .Repeater wrote:. How would this be mounted on the throttle correctly? Is it so the tip of the the thumb rests on it?
Lets talk Grips!
Re: Lets talk Grips!
- Suzuki 2-Strokes: 1974 T500 & 2007 GXS-R 600
Dammitpearljam724 wrote:No different than installing original GT grips. However, I would have measured the GT grips to be sure they are the same length as those you bought. In actuality, yes your thumb should push up against the side of that piece you are referring to. But, I've never gripped a throttle like that a day in my life. Doubt, very few people do.
- Country: U.S.
If they are longer, you're ok. You can cut the end of the tube off, slide the throttle housing and master cylinder closer to the center of the bike to accommodate. If they are shorter, yes you wasted your money.Repeater wrote:Dammitpearljam724 wrote:No different than installing original GT grips. However, I would have measured the GT grips to be sure they are the same length as those you bought. In actuality, yes your thumb should push up against the side of that piece you are referring to. But, I've never gripped a throttle like that a day in my life. Doubt, very few people do.Good catch. I thought the diameter was all i had to worry about. There goes 30 down the drain.
