GT380 Oil leaking from alternator cover.
Re: GT380 Oil leaking from alternator cover.
Nice custom tool! Maybe there should be a sticky topic for specialized and custom tools?
two-stroke-brit
Suzuki 2-Strokes: gt750
Post by two-stroke-brit »
Willgo wrote:I have now fitted a new seal.
Went for a 40mill run on mixed roads let it run up to 80 a couple of times and some acceleration up to 6k and making engine pull in high gyres, but most light cruising.
Got home let her cool down and took off the alternator cover no sign of oil, then removed the alternator windings,
There was a trace of oil in-between the winding casing flange at the bottom?
Hoping it’s what might have been caught up in the windings. :roll: Will give her a good run and check again.
For anyone interested I turned up a piece of alloy with a taper to match that of the shaft on its inside and the same O/D as the shaft, it slips on the taper of the crank shaft butting up to the parallel part of the shaft were the seal runs, so it would have a smooth a transition as pos going onto the shaft. I also turned up a piece of alloy just under the seals I/D bored so that was a close fit on the piece over the taper so it would run square I machined out the pressing face to a depth of 4-5mm so there was only a 3mm face to bear on the seal. I then pressed the seal in by tightening a bolt in to the end of the crank shaft. Worked really well.
Bill.
i think i follow but a pic of the tool would be nice
thanks mark
1973 SUZUKI GT750K.=SOLD
1982 HONDA CB900F =SOLD
1982 YAMAHA RD350LC.
1985 RZ350N
That idea had crossed my mind a while back and its a good idea to have a place to put custom built tools for applications.
+1 :up:
Willgo
Post by Willgo »
Flattered that you find it useful so as pic is worth a 100 words I will shut up
And let them do the talking.
If they post
Bill dag,
