GT500 chain
Re: GT500 chain
428! Where do you find a heavy duty 428? we wear those out on our CB160 race bikes but the chains we buy are usually consumable items. Maybe it's time to search for a better 428
Re: GT500 chain
Well, I have decided to get a DID 530NZ. It is $80.99 from 'Motorcycle Superstore'. It is rated at 8,600 lbs. tensile strength, we will see......
Re: GT500 chain
I'm still tossing around the idea of lathing one side of my spare Titan sprockets by the toothed sections down to a 520 width.
This will allow me to add no spacers and use the X-ring 520 chain, which I already have in my parts stock.
A non o-ring chain needs a lot of care to last, especially if you do a lot of constant high speed riding.
Re: GT500 chain
In case anyone is interested, I dug out Jughead's post on converting to a 520 chain for a T500:
I found the Sprocket Specialist rears were about $55 to $59 per when I ordered them. The fronts I found on Ebay for around $10 per sprocket. And I was able to find 13, 14, and 15 tooth fronts.
As for a chain, since this set-up is narrower you can fit a 520 "O" ring or "X" ring chain with some clearance to spare. I've found the RK GB520MXZ3 (non o-ring) to work well and have excellent tensile strength. Best of all they turn up on Ebay from time to time for around $50 a chain. I ran one on the GT500 based race bike I bought from Mowgli with no problems so it should survive street duty just fine....
Jim
To Adapt the T500 Countershaft Sprocket to a 520 Chain which is Narrower than the Stock 530 Chain you will need to Find a Sprocket from one of the Following Models.
Part # = 27511-41120
Part Description = SPROCKET,ENGINE
Model Count = 20
PE250B 1977
PE250C 1978
PE250N 1979
PE250T 1980
PE250X 1981
PE400T 1980
PE400X 1981
RM250A 1976
RM250B 1977
RM250C 1978
RM250C2 1978
RM250-N 1979
RM250-T 1980
RM370A 1976
RM370B 1977
RM400C 1978
RM400N 1979
RM400T 1980
RS250T 1980
RS250X 1981
To Adapt the rear to a 520 Chain you can contact Sprocket Specialist at http://www.sprocketspecialists.com" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false; and have a stock 530 Rear Sprocket Machined Down for $25.According to Zook-e the $25 Machine Bill covers 1 or More Sprockets to be Machined.
The Part Number for the Front Sprocket is 516 and Comes in sizes 11-16 Tooth and Costs $13.00
The Part Number for the Rear Sprocket is 159 and Comes in Sizes 30-71 Teeth Price Varies on What Size you Order.Cheapest Being $53 and the Most Expensive will be $99
The 159 Sprocket Covers the Following Suzuki Models According to the SS Website.
GS400 77-78
GS425 79
GS 450 80-83, 85-88
GS 550 B, C, N, ET, LZ SPOKE 77-82
GT 380 73-77
GT 500 76-77
GT 550 71-77
T500 68-75
Another Helpful Website with an Online Catalog ishttp://www.jtsprockets.com/52.0.html" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Jim
Re: GT500 chain
Slight change of plans. Am now getting a RK chain and have ordered both sprockets from Wemoto in Britain. It seems very hard to find a stock rear sprocket in the states for a good price. They were about $54.00 with shipping, so the price to me was pretty good.
