Stop obfuscating.
The question here is whether the rising rate that Suzuki designed for the GT still appropriate for modern oils in modern riding conditions. You and Eric say "yes" it's better to back off the pump for street conditions and I say "don't mess with it". How much better is modern oil? Well that depends on the oil. How much different is one person's riding compared to the original design. Only they can guess.
We all agree that from half throttle or thereabouts to the top end makes no difference. The pump will be wide open anyway. The only subject of discussion relates to slow speed/low throttle opening riding. Is less more or is more more? You believe less is better and I wouldn't mess with it. Those are opinions, and they differ, and I can live with agreeing to disagree.
Bottom line is that ridden quietly when it's not too hot and the bike is set up correctly, it can run without oil for a remarkably long time before it breaks. If i did most of my riding sedately/responsibly and I used great oil, I might be tempted to tweak the settings, but I don't, so I won't. Your mileage may vary.
