rngdng wrote:On Gunnar's page, he shows how to use a GT750 head as a puller. I have used this method with success. Lane
Me too...
I'd be very surprised if damage could be done to a head using it as a puller.
Using fine-pitch (e.g. 10x1.25mm) rod and nuts, adequately sized pressure plates/washers, spacers and washers on the 8mm attachment bolts and done methodically and carefully, the stresses on the actual head aren't too bad.
Turning each rod (say) an eighth of a turn each time only imparts movement of fractions of a millimetre at a time to the head itself, which is easily catered for by the flexibility of the alloy.
I've used a head as a puller plate on a couple of engines and not had any dramas.
In fact I'm now using that same head on the bike - it turned out it was the only one in my collection that hadn't been skimmed. It was flat and straight (I checked) and works fine on my stock motor, no leaks or cracks.
All caveats apply of course - I'm not saying you
can't break a head, but if you use common sense you shouldn't go wrong.
Paul
