jabcb wrote:Sorry for the delay.
My charge coils have brown & black wires. The two brown wires connect to Y/G.
Yours is wired up the same. But its possible to install them upside down. Post a link to a pic of your setup
Yup, even before reading your reply I tried switching one around....
I switched the one on the right, so the wires come out on the clockwise position, (like the left). I fired it up, and wolla! Consistant 13.5v going to the battery!
So I went for a ride with the head light on, to give it a workout, which resulted in nearly burning my bike to the ground. Come to find out, the battery that came in my lighting kit -->
https://www.rockymountainatvmc.com/p/11 ... ghting-Kit" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Is a lithium battery. I assumed it had a over load protection built in, but nope. I had flames shooting 2' out the side, under the seat. I managed to get the fire out, but the battery is destroyed, and it melted the tail/brake/siginal light harness.
So now i need to find a battery, small enough to fit under the seat, and not catch fire. I am looking at this one;
https://shop.antigravitybatteries.com/p ... se/ag-401/" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
but this part of the description has me worried:
"Custom builds like cafe racers or small bore customs up to 350cc. (Please note if you use older classic bikes from mid 1980s and earlier you should update the charging systems to a modern voltage regulator; damaged voltage regulator can overcharge the battery and damage it.)
Not for use with PWC."
However I have a updated regulator!
Thoughts?
