No baffles, but I haven't cleaned out the pipes. This bike was under water for a while and then exposed to air with water everywhere. When I took out the sris water/oil came out of the bottom end, and carbs - tank etc were full of water. Nasty ugly lake water too
Surprisingly, once the sris were out and drained, and all the fluids changed (a couple of times), it fired right up, just had a wonky idle which led to the carb rebuild. Now the only thing good about running is the idle (and WOT).
I did pull the carbs apart again last night. One of the bowl passages was clogged (the rear one) in one bowl, and the carb needle jet for center carb was covered on the outside with lake goo, inside didn't look great either. Chokes were working correctly but individual hand activation showed one to be very 'notchy'. Pulled it out and the choke area was full of dirt, the shaft was very dirty. Cleaned all that with carb cleaner and the shaft moves easily without the notchy feeling.
Everything I can find has been blown out with compressed air again, and reassembling tonight with another new set of main and idle jets, as well as new needle jets. Going back to stock petcock as well even though mine flows like prime in all positions, just going to use an inline cutoff.
If all that has no effect, I'll be asking for tips on how to clean out exhausts
