4LS Torque Bolt removal?
odbuffalo
Post by odbuffalo »
Looking to remove the 4LS Drum from the the old forks, how do I loosen/remove the bolts from the torque bars with those brackets o them?
diamondj
Re: 4LS Torque Bolt removal?
Post by diamondj »
The tabs against the bolts are meant to be bent down. Then when you put the bolt back in, you bend the tabs back against the bolt. This keeps the bolt from backing out when the bike is together.
Jim
odbuffalo
Post by odbuffalo »
Ah, bent down, thats the trick.
Thanks!
