Jerry,
You can do fine with your dealer if you go there with part numbers in hand. That way all they have to do is punch the numbers in the computer -- nothing to look up. To obtain the correct and current number, just go to http://motorcitypowersports.com/catalog.asp The third icon down on the left (oem part finder). Follow the links to find your bike. All the part numbers are correct and current. If there is no part number for a piece you are looking at, it means the part is no longer available.
No one mentionrd this so I will. Avoid using Keyster carb rebuils kits. They are junk. About the only thing usable is the float needle and seat and the bowl gasket. The rest is trash.
Before I proceed on T500
Unfortunately, I agree whole heartedly with Coyote on this one. I've been down that road with Keyster, the hard way. Heed, and ye shall learn.Coyote wrote:Jerry,
Cheers.
Fred
Suzuki GT 750s
Ducati 750 GTs
2007 Duc 1000 GT (the clone)
Suzuki RE5s
Ducati 750 GTs
Suzuki RE5s
