Things are progressing, although I haven't been spending a lot of time out there lately.
The carbs are cleaned out, assembled, and adjusted. There was quite a bit of scale buildup in the needle jet bores and that stuff did not want to come out. I finally got it cleaned up with a small round file. Now the needle jets fit properly. I need to get some new float bowl screws and some pieces of fuel line that fit, then I can assemble the carb rack.
Petcock is cleaned out and fitted with new seals. Tank is out getting painted and when it comes back (should be soon) I can test the petcock. I did not replace the little o-ring behind the diaphragm because the diaphragm was stuck to the body, so that may be a problem. We'll see soon.
I'm having the better of the two tanks repainted along with a good pair of sidepanels. They're going to be black with gold striping. I haven't decided if I want to buy the reproductiondecals.com '75 decals or just use some generic tape. The chrome is all good so the bike is going to look really good.
I bought a set of NOS points and condensers from PM so I'll put those in. Kokusan condensers are NLA and the points are expensive so that was a good purchase. As usual with PM, there was no communications at all from him, but he delivered the goods promptly.
I need to get the bike cleaned up too. Weather sucks around here lately so I'll probably take it to a drive-thru car wash one of these days.
Then I can do some assembly and see if it will run! I'm working with the Wyoming bike (the one that used to have the ugly green tank) and using the other one for parts.
Debby
