T500 oil pump leak
Monkey man
Suzuki 2-Strokes: T 250 t500 gt 550
T500 oil pump leak
Post by Monkey man »
Hi guys
I thought I was over the problem of 2 stroke oil lying on top of the crankcase after having replaced the crush washers feeding the oil pipes to the barrels etc
However after removing the carbs I noticed oil was once again ponding on top of the crankcase and appears to be coming from where the rev cable joins the oil pump
In fact I see red 2 stroke on top of the screw fitting that secures the cable down into the oil pump
Is it possible or likely that 2 stroke oil is surging up the oil pump at this junction
I’m absolutely sure it’s not from the 2 stroke tank itself
Any advice or thoughts are welcome
karl pa
Country: us
Suzuki 2-Strokes: GT
Re: T500 oil pump leak
Post by karl pa »
Monkey man wrote: Wed Nov 13, 2024 1:44 pm Is it possible or likely that 2 stroke oil is surging up the oil pump at this junction
I would say yes. My 75 T500 had a leak from oil pump that left a puddle on the crankcase and floor under.I replaced all the o rings and seals with a kit from a member from Canada who sold on eBay. If you replace seals, don't skip the one between the pump and the gearbox, my T250 filled the gearbox with 2 stroke oil when that seal went bad.
I am not sure he sells the kit anymore, I do see a seller in Germany has a kit listed.
76 GT185
77 GT250
77 GT380
73 GT550
73 GT750
74 GT750
71 T250 scrambler
75 T500 cafe
Monkey man
Hi guys - just an update and thankfully the leak is cured .
I took off the pump and replaced top and bottom seals ensuring they were fitted the correct way up (seal facing fluid to be retained )
Put pump back on and re-filled oil tank two weeks ago and all is dry - no more oil lying on top of the crankcase and seeping onto garage floor
Thanks for all the advice
