Hi Guys, I’ve just fitted a modern Reg/rec to my 1973 250 to replace the silicon diode rectifier. Voltage measured at the battery rises from 12.5V to a max of 14.6 at high revs. My question is, will a modern sealed AGM battery be ok to use with that voltage input?
Gt 250 regulator output.
- Suzuki 2-Strokes: 1973 GT250
- Country: WALES
Re: Gt 250 regulator output.
You are fine to use that battery its the lithium battery you have to avoid, because they are charged at a set rate and can catch fire if overcharged
98 carb Blackbird and GT550j
Many thanks for the adviceGTandcbr wrote:You are fine to use that battery its the lithium battery you have to avoid, because they are charged at a set rate and can catch fire if overcharged
