Hello old thread
Found one of those pipes myself a couple of days ago when going through my oil pump parts stash box. I think it came with an oil pump that I bought off ebay many years ago. I didn't need it and actually, I think I just glanced at it....thought it was homemade and put it away. The left side line must have come with it but it must have been the 'non rebuild-able' kind.
I think I'll polish up the brass on this ugly #2 oil pipe and remove the black sealer and use something a little more neutral/ pleasing to the eye and look to buy it's #3 brother somewhere so I have a matched pair that I may very well need. I've had a true NOS later pair of lines in the original packaging for many years but I can't bring myself to use them.
I could not find a part number in an old parts book pdf for these lines but according to some of Ian's research, the earliest parts numbers for the #2 and #3 oil pipes were 16820-15030 and 16840-15030.....
https://www.oldjapanesebikes.com/mraxl_ ... s/page-A57" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;"
A little more reference to check valves here (scroll down)....
viewtopic.php?f=23&t=9437" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Here's the rightside (#2) from my spare parts stash. I hung it and some other ones (later version)up overnight and with no leaks from the check valves on this one.
.....but had flushed out a little blockage from the engine side of the of the ball,in the banjo itself.....
beetlejuice...beetlejuice
Note the spring taper for the ball
