Suzuki2Strokes.com
Sundial Moto Sports
Suzuki2Strokes.com
It is currently Thu Apr 26, 2018 3:27 am
Post new topic Reply to topic  [ 6 posts ]
Author Message
 Post subject: Flooding RT cylinder
PostPosted: Sun Jun 18, 2017 9:34 pm
Offline
Bikes owned: GT 250. GT380, Gt 550
73 GT250 Rt side floods upon start up, has been running good. Carbs have been cleaned and all passages are clear, needle valve does not leak, pilot jet, main jet clear..spark seems equal on both sides, 150 compression both cylinders. Is there anything else that would create this issue other than carburetion? Best Wishes Tim
Top
 Profile
 Post subject: Re: Flooding RT cylinder
PostPosted: Mon Jun 19, 2017 5:20 am
Offline
Choke plunger not closing might cause that.
_________________
Top
 Profile
PostPosted: Mon Jun 19, 2017 5:35 am
Offline
Country: United Kingdom
Bikes owned: T500_MKIII
Had a similar issue, which I believe was due making my own float bowel gasket out of thicker than OEM material. I think this caused the arc of the float travel to touch the side of the float bowel and stop it closing fully. Hard to prove definitively and could be the act of taking it apart again cured something else and going back to stock gaskets was a coincidence.
Top
 Profile
PostPosted: Mon Jun 19, 2017 11:24 am
Offline
Bikes owned: T500 RGV250
I've just been chasing a similar issue with my T500, turned out one of the floats had a crack in it and had partially filled with petrol. So might be worth making sure both your floats float properly :)
Top
 Profile
PostPosted: Mon Jun 19, 2017 5:06 pm
Offline
I'm going to check float level. Anyone know what the measurement should be. Not sure of the exact model ( letter, number combo) On a Mikuni VM34 it's 22-24 MM. Also would a weak spark cause fuel not to ignite? Seem to have equal spark on both sides. Best Wishes
Top
 Profile
PostPosted: Mon Jun 19, 2017 5:13 pm
Offline
Top
 Profile
Who is online
Users browsing this forum: No registered users and 18 guests
Search for:
Jump to:
Suzuki2Strokes.com
