well about 2-years ago maybe 3 I had to replace the swing arm bushings so I opted to replace the chain at the same time, the guy at the bike store told me the o-ring was the way to go and I asked him if it would fit and he looked it up and said yes,,,i remember it being said they wouldn't fit? but I decided to try it, and it was damn close but did not rub on anything so I thought wow I got lucky or people don't know what they are talking about
,,,,long story short I got an oil leak from the the sprocket side, somewhere not sure where so I took the case off and hell!!!!the damn chain wore down the aluminum behind the sprocket!!!!!
,,,as best as I can tell this is not my oil leak ,,,seems oil is leaking from behind the sprocket but not the case ,, or maybe gear shifter not sure I need to clean things better just saying it did not wear the aluminum down to where theres a hole just freakin wore it down perfect for the chain to fit
,,so anybody had this happen? or am I'm the only dumb ass that has encountered this ?? its weird because I checked and double checked it and it never hit or rubbed on anything ????, maybe this happened from giving my wife rides? extra weight ? she has been on a diet
,,no but seriously should I leave the chain? I'm assuming it wont get worse and its been about 3 years now so I would think I'm good? and now my motor is perfectly ground for an o-ring chain
,,also I have replaced the seal or whatever it was(don't remember ,getting old) behind the sprocket before because it leaked and it stopped for a little while and now its doing it again,,???? any thoughts thanks! or it could also be the gear indicator leaking ? I remember I replaced something on that side that I knew for sure was leaking and it stopped for a few years and just started again ,,,,damn I cant remember a couple of years go by and in my brain its like 20 years have gone by crap.......
