Does my GT500 Cylinder Puller look right to you?
Re: Does my GT500 Cylinder Puller look right to you?
Conner is the GT engine the same as the previous years T500? If so they can always get everything the trash can can hold from Luzinimage.
- ConnerVT
- Novice racer
Been told the cranks are slightly different (crank ends for sure) from a reliable source. Not sure if the main and large end bearings are different or not, but likely the same. If not, doubt that availability is any better.
I also would avoid the Cruising Image bearings. Too many questions, too many bad things said.
I had one of my projects really stuck like that, and I had to resort to using a puller setup to push the piston down. I did put a woodblock on the piston. I was fortunate in that the studs are full length so I removed them. Once I got the cylinder up enough, I pulled the wrist pin, and used a BFH and vise to pound the piston out. Worst I've ever seen. Crank was just as bad.
