T piece.
Robbie8819
Suzuki 2-Strokes: 1974 GT550, 86 RG500G, 82 CB900F
T piece.
Post by Robbie8819 »
)n the carbs on a 74 GT550 there is a T piece coming from the inside of carb 1 and 2 which connects the three carbs. Where does the open ended part of the T piece go? Is it an overflow or a balance piece or what is it?
Any help would be great.
Thanks.
Robbie
Love the smell of Castrol R in the morning.......
1986 RG500
1975 GT550
1982 CB900F
Re: T piece.
If it's the plastic piece you speak of, it's a vent. The factory had hoses on them but it's totally not necessary. Just leave them open.
Robbie8819
Re: T piece.
ok thanks. tried that now. still runs like crap. will run with choke on but not without. Ideas? air screws make no difference tried all at different settings.
Robbie
1986 RG500
1975 GT550
1982 CB900F
Re: T piece.
Most likely partially blocked pilot jets and or their passages. The choke is delivering the fuel that the pilots can't. Does it die right off when you switch the choke off? That's a definite sign the pilots are no delivering fuel.
Re: T piece.
Agreed. Clogged pilots.
