Left hand switch----- CHEAP!
Found this while cruising Amazon. No HI/Lo so you would have to rig something different. But look at the Price!
http://www.amazon.com/Signal-Light-Hand ... rn+signals" onclick="window.open(this.href);return false;
rocc99
Suzuki 2-Strokes: 72 T350, 98 Bandit S
Re: Left hand switch----- CHEAP!
Post by rocc99 »
I put one of these my my T350 since my stock switch was totally fried. It does have a high/low, no on/off switch though. I ended up wiring for the light to always be on, which I appreciate anyways. Uses a 6 pin connector vs the 9 pin in the headlight, but, just so happens that the six pin still slides in just fine...then I just used bullets to connect up the others. Had to switch some of the wires around within the 6 pin connector, but pretty dang close to plug and play, and decent quality, at least for 10 bucks!
