'73 T500 proper float height adjustment
mafd2
Suzuki 2-Strokes: T500 GT550 RM125 RM250 TS250 RM400 CR250,
Post by mafd2 »
When checking float height on T500 K carbs with a float gauge, do you check from the base with bowl gasket removed, gasket installed or from the lip of the carb body? I've heard different ways. Shop manual or Haynes manual doesn't say. Haynes manual also shows carb body straight up and down when measuring??? Shouldn't the carb body be tilted until the float just starts to depress the plunger on the needle valve? Thanks
parksie
Suzuki 2-Strokes: Suzuki t500 69,71,73, Gt500 76
Re: '73 T500 proper float height adjustment
Post by parksie »
From the base with bowl gasket removed, I also measure it sideways as well, like you said just as it touches the valve.
1969 T500
1973 T500
1971 T500 (being restored)
1976 GT500 (being restored)
2012 Ninja 650
ConnerVT
Post by ConnerVT »
Base, no gasket. Tilted, as not to compress the float pin spring.
mafd2
Post by mafd2 »
Thanks for confirming guys.
