Really hard shifting into 2nd?
MikGsxr
Post by MikGsxr »
Hello all, took the t500 for a run yesterday and after about 30kms, shifting into 2nd from 1st became extremely difficult. i had to put a lot of force into the shifter to get it to shift, normally it pops right in, no problems although I have never been able to get it into neutral while running. Any ideas on what might cause this? i am running standard gear oil at the appropriate levels...
thanks!
Re: Really hard shifting into 2nd?
Use engine oil not gear oil. Might be too thick.
Or has yours had the mod done for oil level?
MikGsxr
Post by MikGsxr »
Mine is a 74 model so has the 1400cc capacity. i might have to drain and remeasure...
Sounds like a poorly adjusted clutch. In my experience there's not a lot between drag or slip on the 500 clutch.
MikGsxr
Post by MikGsxr »
Thanks for the replies. would it still be clutch adjustment even though it shifted fine for the first half of the ride? It was not until I was closer to home it started doing it (after the oil was hot). Thanks
Mike,
It could. I found my newly rebuilt 550B like this - OK cold / cool, but could not go 1st to N or 2nd when stationary, once fully hot. OK if I rolled off and then shifted. I tweaked the clutch pushrod / lifter thing under the outer sprocket cover in a 1/4 turn and ever since, its been fine cold and hot.
MikGsxr
Post by MikGsxr »
Thanks mike, I will give that a try today!
Cliff
Post by Cliff »
Agree with the above, check the clutch.
How did you get on?
titan performance wrote:How did you get on?
Just sling a leg over and away you go.
Can't beat legover. :shock:
Ha ha....honest to goodness northern wit ! Love it, 'appen !
