I had the same problem with a T350. Was not possible to get the boot on the carbs. Had just bought the bike & it was so bad that I checked to make sure it wasn't a boot for a T250. (Didn't know that T250 carbs are a lot smaller.)
Did a lot of research on the web and found a solution.
Used Rubber Renue from MG Chemicals. Used about half a small bottle. Applied it to all surfaces with a paint brush. Then put the boot in a plastic bucket with a air-tight lid. Put some metal in the bottom of the bucket so the boot wouldn't touch the plastic. Let it sit for a few days. Boot was then pliable enough to easily put it on the bike.
Don't know if its an issue, but I used rubber gloves & a well ventilated area.
I use a Sears Craftsman cotter pin extractor tool to align the boot to the carb inlets. Makes alignment quick & easy on my T350.
Hope this helps.
GT750 Carb Boot Issue - Help Please
- Suzsmokeyallan
Re: GT750 Carb Boot Issue - Help Please
Mike there are two boots on ebay if you have not found one yet.
Thanks guys. I have managed to find one and it should be here soon. The hunt is half the fun with these restos don't you think?
72 GT750J
71 TS250R
71 H1A
72 GT750J
71 TS250R
71 H1A
