1976 Suzuki GT500 vintage drag bike project
Chris D
Post by Chris D »
Up for sale is my 1976 Suzuki GT500 vintage drag bike project.
First off:
Frame is a 1976 suzukigt500, frame is braced and is modified for expansion chambers, also the frame is modified so the foot pegs are moved back 6". Steering is also restricted.
Engine:
1972 suzukit500
heads cut
cylinders ported and polished, also angle milled
new suzuki top end 1.0mm over. Only suzuki parts used.
Crankshaft overhauled with new seals, crank welded and holes plugged in flywheels.
Swarbrick expansion chambers
34 VM mikuni carbs installed
oil pump system left on. small oil reservior mounted.
charging system removed, runs off small 12v battery
new front aluminum rim and spokes from buchanans, also laced there. new front tire
1977 gt750 forks on the bike.
dual front discs off 1982 gs1100
dual front brake calipers and master cylinder off 2004 gsx 600
rear caliper and master cylinder off 2004 gsxr 1000
fuel tank off a 1976 gt750
onlins steering dampener
I'm sure im missing stuff!
if you would like to see pics ill have to email them too you. not sure how to use the site yet.
Having fincial difficulties and the bike regrettably has to go
I have over 6000 invested looking for 3000 obo
