As Subj says.
Very willing to send $100 plus shipping to buy!!
-Eric
Want to buy/rent/borrow/beg puller plate for 750 barrels
- Suzuki 2-Strokes: GT750
Smoketriples
current stable:
'75 Zooki GT750 (rider)
current stable:
Re: Want to buy/rent/borrow/beg puller plate for 750 barrels
I have one you can rent but shipping maybe a problem its heavy around 20# were are you.
Ride on even after it all over
Funnily enough, there is one on eBay currently - item 300567404720.
Thanks Ian, just added to my auction sniper!! Been searching for days and then when I don't look, one turns up
You're probably the furthest member away from me
, I'm in North Carolina, but if I can't win that auction lets look into what shipping both ways would be.
I don't have a suitable drill press or bits, and the investment in all that to make one plate isn't worth it.....
=Eric
=Eric
Smoketriples
current stable:
current stable:
I made one myself with a hand held power drill. I used a head gasket as a template and started with a 4mm drill bit. After i increased to the correct size for a M10 thread tap (9,5mm?). Didn't take long at all, just buy a good drill bit and use cutting oil to lubricate. Same with cutting the threads, get a good quality tap.
My biggest problem was actualy getting the steel plate to make it from.
Well, I'm hoping to get the one on fleabay. If that fails then it's off to the store for a drill press and taps. I'm sure I'll find more uses for the press.
Depending on what this ebay one goes for I might just make more than one and try to sell a few there.
-e
-e
Smoketriples
current stable:
current stable:
