T350r Spares
saab9002
Country: uk
Suzuki 2-Strokes: GSX250,GT750.GS850G,2XGT250 GT550M, T350R
T350r Spares
Post by saab9002 »
i have a list of spare parts I would like to move on, I have tried to enter all the items here but the list is too long, there are 53 different NOS items, ranging from 1 off to 15 off of different parts plus 23 different items all good but used parts.
I would like to sell them all as a job lot, so serious enquiries please, and I will email a list
saab9002
Country: uk
Re: T350r Spares
Post by saab9002 »
The list of spares. I would prefer to sell this as a job lot.
SUZUKI T350R SPARES
ALL NOS.
Various Gaskets
Air Filter.
Rubber Bungs 34955-16420
Rubber Bungs 34956-15100
4 off Throttle Adjustment Rod 13296-15010
6 off Exhaust to Barrell gaskets 14181-36A00
Steering Lock+ keys 51910-25311
2 off Headlamp Bulbs BU620
Headlamp Bulb Rear Rubber
4 off Spark Plugs B77HC
Carburettor Slide 13551-18010
2 off Brake Shoes
Oil Tank Rubber Strap
Kick Start Rubber 26352-01000-000
Oil Tank Viewer 44640-11843
4 off Carburettor bowl Gaskets 13251-33110
4 off Carburettor Manifold Gaskets 13125-30000
3 off Gearbox Needle Roller Bearings 09263-17001
2 off Big End Needle Roller Bearings 09263-20020
2 off 16mm Small End Needle Roller Bearings 09263-16015
Front Brake Warning Light Cable 57470-15110
Set of Point + Condenser
Ignition Switch + keys
10 off Circlips 09381-16001
Relay 36810-32210
Various Carburettor Spares
14 off Aluminium Gaskets 09168-06004
15 off Carburettor “O” rings
L/Hand Side Panel Screw 47230-01000
Spring 09448-30001-XCO
Gearbox Cushion Shifting Collar 09320-13001
5 off Screws 02122-06128
6 off Petrol Tank Cap Pins
Various Gearbox Spares
2 off Speedo Cables (Grey) 34910-18230
2 off Rev Counter Cables (Grey) 34940-15030
Clutch Cable (Grey)
Front Brake Cable (Grey)
Gearbox Cam 31724-18521
Rear Brake Lamp Switch 37610-53011
Oil Tank Cap
Complete Tool Kit 09800-21028
Wiring Loom 2 pieces
Spring 51455-31010
6 off Gaskets 11241-18001
9 off Head Gaskets 11141-18000
Pair of Mirrors
Complete Throttle/Oil pump Cable (Grey)
New Throttle Cable 1st part (Grey)
2 off Carburettor Springs
2 off Carburettor Top Dust Covers
Drive Seal 09283-27003
Pushrod Oil Seal 09285-06009
Bolts for Oil Pipes
Used Parts in Good Condition
PAIR of T350 Carburettors (Ultasonically Cleaned)
T250 Petrol Tank incl. Badges and Cap
Fuel Tap C/W new Rubber Vacuum 44300-18450-000
Fuel Tap C/W new Rubber Vacuum needs Seal kit
T250/350 Oil Tank
saab9002
Country: uk
Re: T350r Spares
Post by saab9002 »
Apologies, the list didn't load properly. Please add these to the bottom of the above list:-
L/Hand Side Panel
L/Hand Side Panel trim
Various Carburettor bits
T250 Petrol Tank Locator Bungs 27mm dia
Gearbox in pieces
3 off Pairs of Coils
2 off Oil Pumps
Speedo/Rev Counter Bracket
Ignition Switch
Set of Oil Pump Pipes
2 off Generators
Rectifier/Cable
3 off Complete Throttle/Oil pump Cables
Clutch Cable
Twist Grip
2 off Brake Shoes
T350/T500 Headlamp Bowl
T250/T350 Early Headlamp (Stanley)
T250/T350 Early Headlamp Rim
Headlamp 110-32787
T250/T350 Early headlamp Bowl
T350 Rear Indicator inc. Stem
T250/T350 Bottom Yolk
15 off Spacer Rings for Headlamp/Reflector to Forks (some NOS)
2 off Pairs of Headlamp Ears (1 set Rechromed)
Pair of T350 Heads (Straight Fins) Vapour blasted/Polished
Pair of T350 Barrels Vapour blasted
Pistons Various +’s Some NOS
Various Gudgeon pins/Needle Rollers
Complete T350 Clutch
regards Chris
Re: T350r Spares
Email Chris for further details & prices.
saab9002
Country: uk
Re: T350r Spares
Post by saab9002 »
All Sold.
regards Chris :)
saab9002
Country: uk
Re: T350r Spares
Post by saab9002 »
I couldn’t believe how much interest I got about it, even ignoring say 50% that had no intention of getting a deal done, I reckon I could have sold
the job lot 10-12 times. It all ended up going to Scotland and they’re supposed to be careful with their money🤐
Thanks to all who showed an interest but it went to the first committed buyer.
Regards Chris
